Keystrokes not recognized in event case
I've been messing with this all morning and it just doesn't make sense. After I enter an event case, keystrokes are not being recorded in a string control. I thought at first it was because "Update value while typing" wasn't checked but that didn't help. Please see the attached VI.
Here's what's supposed to happen. The keystrokes will eventually come from an RFID device, but for now typing from the keyboard does the same thing. When the VI is entered it sets the key focus to the "RFID ch" control. Then it waits for a "[", then clears the control and waits for text followed by "]". After that the "Key down" event for that control is released and a "Key down" event for "RFID pump" is registered and key focus is set for that control. Then basically the same thing happens for the newly registered control except it waits for "<text>". For some reason after the "<" is recognized it stops getting data from the control. Any ideas why? I've tried creating a new control instead of RFID pump, but it does the same thing. The stuff that happens in the second event is exactly the same as the first. I can't see why it won't work.
George
Download File:post-2786-1218125368.vi
I think you need to right-click on the second "Key Down" registration in the "Register for Events" node inside the "<RFID ch>: Key Down" event and uncheck "Lock Panel Until Handler Completes". You should probably do the same for the node outside the loop as well, just for consistency.
Jaegen
QUOTE (george seifert @ Aug 7 2008, 12:10 PM)
I've only taken a quick cursory look at your VI, but a better approach would probably be to remove the while loops from inside your event cases, and instead use a shift register in the outer loop to build up your string each time a key down event occurs, until you reach the termination character.
QUOTE (jaegen @ Aug 7 2008, 11:53 AM)
Ah that's it! I didn't know that option was there. I was looking for that option under the actual event, but it wasn't there.
George
QUOTE (ned @ Aug 7 2008, 12:51 PM)
I think you're right about that. I was doing a quick and dirty to check out the dynamic event handling.
