jorwex Posted August 22, 2008 Report Posted August 22, 2008 Hello all, I'm using an ActiveX object that I found ( http://www.shrinkwrapvb.com/videocap.htm ) to display a live image from an Epiphan VGA2USB device. It shows up as a TWAIN (I think that's the correct way to describe it) source if you go to My Computer in Windows. When I first tried to get it to work (All I did was put the video window in an ActiveX container) the colors were all screwy. I managed to get the built-in Windows capture parameter window to display (lets you select source's resolution and bit depth) at the beginning of the program execution. Once I changed it from the default (as its shown in the image above) to RGB24, everything looked the way it was supposed to. Is there a way to programmatically set this prior to execution? I'm not a programmer and I'm having difficulty deciding whether that's a task for the ActiveX object or if it's something I need to set in the OS. I immediately looked to the OCX file, but I think its a Windows setting now, but I don't know where to start. Thanks LAVA, Jordan Quote
TobyD Posted August 22, 2008 Report Posted August 22, 2008 QUOTE (jorwex @ Aug 21 2008, 02:44 PM) Quote Hello Hello! Quote
jorwex Posted August 22, 2008 Author Report Posted August 22, 2008 QUOTE (TobyD @ Aug 21 2008, 05:54 PM) Quote Hello! Hehe sorry about that initial empty post! My finger slipped *Fixed* Quote
