Scatterplot Posted August 26, 2008 Report Posted August 26, 2008 I have a need every now and then to create several instances of the same VI. I was wondering if it was possible (in order to save space and make program flow neater) to make a subVI that is expandable, similar to many of the array functions. For instance, "Build Array" can be expanded by the drag-down menu to make more inputs for you to build the array from. Is it possible to make my own subVI with that functionality? I suppose I could make the subVI polymorphic with support for arrays of whatever data type I'm using, and when it sees an array of (data type X) repeat the operation on each element of the array, then return another array with the all of the elements operated on, which I could then index... but at that point it's become rather messy, defeating the desire to make an expandable subVI in the first place. Thanks for your help! Quote
Norm Kirchner Posted August 26, 2008 Report Posted August 26, 2008 To make an 'infinitely*' expandable sub vi is not possible. You can do some interesting things with right clicking a SubVI and changing the "View as Icon" context option. You would need to make a VI w/ the most items on the connector pane, have them all wired up, have some fancy logic in your underlying code, and you would be limited by number of connectors on the pane..... but it might get you close to what visually you're looking for. Now, if you want to go up in the attic of LV and are willing to get tetanus on a rusty nail, I suggest you look into XNodes. I'm sure others will be chiming in soon w/ more info on that. Quote
