Currently Executing VIs
I always wondered to know if there were any method to identify which part of the code in VI Hierarchy is being currently executed by labVIEW execution. The execution status of the VI say Running for all the VIs in the Hierarchy irrespective of which part of the code is getting is executed. Is there any way ?
QUOTE (RAJKU @ Aug 30 2008, 01:55 PM)
You can do this by looking at the type of arrow the Run button shows
see the attached image
Looks like you can't. See here for another attempt.
One option would be to add a VI (or two) which will register and unregister its caller in a master list when it starts and stops running, but you would need to add those VI to every single VI that you want to monitor, which makes it impractical.
