manikanth Posted September 3, 2008 Report Posted September 3, 2008 hi.. i m new to lab view m making a simple project i.e to control a simple electronic circuit.only on and off functions should be done from the system please somebody help me................. Quote
Tim_S Posted September 3, 2008 Report Posted September 3, 2008 QUOTE (manikanth @ Sep 2 2008, 02:29 AM) m making a simple project i.e to control a simple electronic circuit.only on and off functions should be done from the systemplease somebody help me................. You haven't listed what hardware you are using to perform the control. Is this a NI DIO card? Parallel port bit? Ethernet device? I assume you are using a DIO card, in which case I recommend looking at the example code that ships with LabVIEW; there are digital output examples that ship with LabVIEW. Tim Quote
Scott Carlson Posted September 3, 2008 Report Posted September 3, 2008 QUOTE (manikanth @ Sep 2 2008, 02:29 AM) hi..i m new to lab view m making a simple project i.e to control a simple electronic circuit.only on and off functions should be done from the system please somebody help me................. Will you be using transistors or relays to power your circuit? Really man, how can we answer a question without you providing one with substance? -Scott Quote
