Aaron L Posted September 3, 2008 Report Posted September 3, 2008 Hello, I'm attempting to take a 33 entry array, expand it to 1024 entries with the 33 original entries evenly spaced. Then, I need to linearly interpolate between each of those 33 spread-out entries and fill in the remaining 31 blank entries in between each original 33 now evenly spaced entries. I've found one example about using array expansion, but I have to do this operation many times, so I need to be more efficient about it. This is to fill up a lookup table (LUT). Ex: Take the original: 1 2 3 ... 30 31 32 And create the expanded: 0 (1/32 * (entry 0 - entry 1)) (2/32 * (entry 0 - entry 1)) ... (31/32 * (entry 0 - entry 1)) 1 (1/32 * (entry 1 - entry 2)) ... I can perform this expansion in a brute force method, but the Interpolate 1D Array VI suggests a much more effecient method that escapes me. There doesn't seem to be any good examples for the general operation of the Interpolate 1D Array VI to learn from. It appears to auto-index and take care of several operations at once, requiring a non-indexed entry into a FOR loop. Any guidance is greatly appreciated. Quote
Neville D Posted September 4, 2008 Report Posted September 4, 2008 Look at the Align and Resample Express VI. N. Quote
hfettig Posted September 4, 2008 Report Posted September 4, 2008 QUOTE (Aaron L @ Sep 2 2008, 06:26 PM) I'm attempting to take a 33 entry array, expand it to 1024 entries with the 33 original entries evenly spaced. Depending on how often you will need to access this 1024 item LUT I would not bother with creating it but rather work directly from the 33 item LUT: http://lavag.org/old_files/monthly_09_2008/post-1022-1220403372.png' target="_blank"> The code above allows you to specify a base 1024 index that interpolates the answer from the base 33 LUT. If you will be accessing the base 1024 LUT very often it might make sense to create an actual LUT. Just take the code above and run it through a for loop. Cheers, Heiko Quote
Aaron L Posted September 4, 2008 Author Report Posted September 4, 2008 QUOTE (Neville D @ Sep 2 2008, 04:28 PM) Look at the Align and Resample Express VI. Neville, Thank you for the suggestion and direction. Attached is a VI I made using the Align and Resample function as well as just the Resample function. The VI contains both versions and show the difference. One thing I had to do was add one point to the end of the array to box in my endpoints. For whatever reason, the resample leaves off the last point. One thing I also had to do was make sure my original data point values showed up in the resampled waveform. This means only 2^(-n) sampling could be used. Fortunately, my resampling is 1/32, so I lucked out there. Hopefully this will be helpful to someone in the future for expanding arrays in labview using resampling. Quote
Neville D Posted September 4, 2008 Report Posted September 4, 2008 QUOTE (Aaron L @ Sep 3 2008, 10:35 AM) Neville,Thank you for the suggestion and direction. Attached is a VI I made using the Align and Resample function as well as just the Resample function. The VI contains both versions and show the difference. One thing I had to do was add one point to the end of the array to box in my endpoints. For whatever reason, the resample leaves off the last point. One thing I also had to do was make sure my original data point values showed up in the resampled waveform. This means only 2^(-n) sampling could be used. Fortunately, my resampling is 1/32, so I lucked out there. Hopefully this will be helpful to someone in the future for expanding arrays in labview using resampling. Great! As a sidenote, if using the ExpressVI, double-click it, change to VI and then edit it to remove unnecessary functionality and data conversions to get better performance. Digging around inside might also point you to why you seem to be losing the last pt on resample. <EDIT>: Playing around with Open or Closed Interval boolean in the ExpressVI seems to generate the extra last pt, but I can't seem to get my head around the concept at the moment.. N. Quote
