How can contact between Labview and capture system on computer
QUOTE (dangan @ Sep 3 2008, 04:02 AM)
Hi everybody, I am researching to labview. If I want connect between labview control and capture system on computer, how can I do?. I want use Labview control probe of ultrasound on Ultrasound machine.Thank you
Your question needs some more detail to provide an answer. LabVIEW supports many communication protocols for talking to external devices including serial, TCP, CAN, ProfiBUS, and DeviceNet. LabVIEW supports ActiveX, .NET and DLL calls for interfacing with code on the same computer. This provides a huge range of options to where, to date, the only code that I'm personally not been able to communicate with was never seriously updated from a DOS application.
Tim
