Germano Posted September 6, 2008 Report Posted September 6, 2008 That's what happned when I tryed to Install the Second CD Does anyone can help me? I did a complete instalation with the First CD and it did't install yet. where can I find them? Thanks RTX Runtime not present You must have RTX Runtime 5.5 installed before you can install NI-VISA for RTX. LabWindows/CVI Support In order to install NI-CAN support for LabWindows/CVI, it must first be installed on your system. To Continue, click the back button and deselect the LabWindows/CVI support option. To add NI-CAN support for LabWindows/CVI support once LabWindows/CVI is installed, rerun this installer. LabWindows/CVI Support In order to install NI-DNET support for LabWindows/CVI, it must first be installed on your system. To Continue, click the back button and deselect the LabWindows/CVI support option. To add NI-DNET support for LabWindows/CVI support once LabWindows/CVI is installed, rerun this installer. Quote
Yair Posted September 7, 2008 Report Posted September 7, 2008 You should probably call NI to get some phone support, but you can also try at NI's CVI board. Quote
Germano Posted September 8, 2008 Author Report Posted September 8, 2008 I still have problems When I try to see any document about this on NI forum, says: "You are not authorized to view this document" So, I'm blind there, I have to look for out of NI Forum Does anyone know about it? Thanks for respond If anyone could see, there's a enter on NI forum about it on a topic there, but I can enter. LabVIEW Real-Time Module for RTX Installer Requires RTX Run Time http://digital.ni.com/public.nsf/allkb/293...0C?OpenDocument Probably I know what it means now, the licence. But what licence permit these drivers? What are the licences existents to Labview? Could anyone show me a list? These drivers are out of any licence?! even you have a full version? Thanks Quote
Yair Posted September 8, 2008 Report Posted September 8, 2008 I can't access that link you provided either. Again, the best thing for you to do would probably be to call your local NI office and get direct phone support. Quote
