LAVA 1.0 Content Posted September 12, 2008 Report Posted September 12, 2008 I was measuring analog and digital pulses for same event.Also we are acquiring analog and digital with different sampling ratesInitially both the acquisitions happening at same time and running at same rate,but after some time,digital acquisition going slow and values I was getting are deviated from analog in milliseconds are using M Series PXI 6254 Card,How can i make both the acquisitions to happen at same rate throughout the test. Regards, Naresh.N Quote
LAVA 1.0 Content Posted September 12, 2008 Author Report Posted September 12, 2008 You should have a look at the examples (Hardware IO\DAQmx\Multifunction) A similar question is found here Ton Quote
