souske Posted September 13, 2008 Report Posted September 13, 2008 Hi all, I am trying to set up communication between Met\Cal (Fluke's Metrology Softwre) and LabView. I've noticed that Met\Cal 7.2 has support for NI-VISA driver. I tried to use it but I can't force Met\Cal to use "TCPIP::127.0.0.1::<port>::SOCKET" syntax, instead it tries to connect to "TCPIP::127.0.0.1::inst0::INSTR" and generates an error. Has anyone used this, or know how to set up TCPIP connection with Met\Cal? Regards souske Quote
TobyD Posted September 16, 2008 Report Posted September 16, 2008 QUOTE (souske @ Sep 12 2008, 03:04 AM) Hi all,I am trying to set up communication between Met\Cal (Fluke's Metrology Softwre) and LabView. I've noticed that Met\Cal 7.2 has support for NI-VISA driver. I tried to use it but I can't force Met\Cal to use "TCPIP::127.0.0.1::<port>::SOCKET" syntax, instead it tries to connect to "TCPIP::127.0.0.1::inst0::INSTR" and generates an error. Has anyone used this, or know how to set up TCPIP connection with Met\Cal? Regards souske Cross-post from http://forums.ni.com/ni/board/message?board.id=170&view=by_date_ascending&message.id=355301#M355301' target="_blank">here Quote
