jlaudie Posted September 13, 2008 Report Posted September 13, 2008 Classic problem. Never known the best way to get around this. If you are measuring using a frequency DAQmx task, and you have a zero-frequency signal (no pulses--high or low the whole time), the DAQmx will wait the timeout and throw an error. What's the best way to deal with this scenario? 1) Ignore the error -- you're still stuck waiting for the timeout... 2) Count events? How would you pull a timestamp to then calculate your own frequency? I've got to think that there's a slick way to do this and I'm just not aware of what it would be. Thanks ahead of time... Quote
crelf Posted September 13, 2008 Report Posted September 13, 2008 QUOTE (jlaudie @ Sep 12 2008, 02:27 PM) Quote If you are measuring using a frequency DAQmx task, and you have a zero-frequency signal (no pulses--high or low the whole time), the DAQmx will wait the timeout and throw an error. What's the best way to deal with this scenario? Yep - it's an age old problem - you can't measure the frequency of a signal that's period is larger than your timeout I wouldn't so much ignore the error, but filter it and output a number that represents the lowest frequency that your timeout allows. Quote
jdunham Posted September 13, 2008 Report Posted September 13, 2008 QUOTE (crelf @ Sep 12 2008, 12:37 PM) Quote Yep - it's an age old problem - you can't measure the frequency of a signal that's period is larger than your timeout I wouldn't so much ignore the error, but filter it and output a number that represents the lowest frequency that your timeout allows. Crelf's implied point is that you should pick a timeout as short as you can, limited by the smallest frequency you care about measuring. Quote
crelf Posted September 13, 2008 Report Posted September 13, 2008 QUOTE (jdunham @ Sep 12 2008, 03:21 PM) Quote Crelf's implied point is that you should pick a timeout as short as you can, limited by the smallest frequency you care about measuring. Indeed. Quote
fhinali Posted September 16, 2008 Report Posted September 16, 2008 QUOTE (crelf @ Sep 12 2008, 08:37 PM) Quote Yep - it's an age old problem - you can't measure the frequency of a signal that's period is larger than your timeout I wouldn't so much ignore the error, but filter it and output a number that represents the lowest frequency that your timeout allows. A good way, I agree with you! Quote
Kevin P Posted September 17, 2008 Report Posted September 17, 2008 One tiny suggestion: when I've had a need for this kind of thing, there have been 2 or 3 ways to consider handling it. 1a. (Applies to an unbuffered freq measurement task.) Use a short timeout value. On a timeout error, clear the error and report 0 freq for that software query interval. Attempts to report the instantaneous freq *right now*. In absence of pulses, 0 Hz is a reasonable estimate. 1b. (A variation of 1a for certain kinds of apps.) On a timeout error, clear the error and report the most recent successfully-measured freq, which you could store in a shift register. Reports the freq of the most recently observed actual pulse. 2a. (Applies to a buffered freq measurement task with continuous sampling.) More complicated, but has its uses. Sometimes I want to do some averaging or trending across the most recent N freq measurements. I configure the task so that the Read call returns the N most recent samples. If there are no new ones from one loop iteration to the next, I'll end up reporting the same old (stale) average. 2b. (A variation of 2a.) I may choose to query the task for the TotalSamplesAcquired on each pass through the loop. Then I can do different stuff if I notice that value remaining constant over several iterations. In rare cases, I may even combine that total with a query for the software msec tick count as a cruder measure of recent average pulse rate. It can help as a sanity check sometimes. -Kevin P. Quote
