Matarese Posted September 24, 2008 Report Posted September 24, 2008 I have found a bug with the new ”Clean up diagram” function; When I have a conditional disable structure with a subdiagram that are disabled and the subdiagram have a broken wire and use the ”Clean up diagram” function I get LabVIEW to crash. Se the attached vi; If you open the diagram and press on the ”Clean up diagram” button you get a crash, but if you remove or fix the broken wire on the disabled subdiagram and press on the ”Clean up diagram” button it work fine. Quote
Aristos Queue Posted September 24, 2008 Report Posted September 24, 2008 This was reported to R&D (# 127394) for further investigation. Quote
