How to do a image collage?
Hi every one... I have Labview 8.0 and I've been trying to do an image collage. I'm using a camera to take photos of something moving horizontaly and what I'd like to do is to paste them so I can have the full sequence of images together. I did it with a sequence structure and it works well but I would like to do it with a for sequence. The problem is with the for sequence the pixel tables are pasted vertically. Does anyone know how can it be done????
I hope I'm being clear... :wacko:
I attach to this message 2 snapshots : one of the diagram (this one shows the solution with the sequence structure and the diagram with the for sequence that does not work correctly) and another one of the front panel with the results of both diagrams.
Thank you in advance,
Best regards
Carlos Torres
Hi Carlos,
a few things.
1- To append horizontally, just Transpose your 2D array before appending images. After you're done, transpose again to get final result.
2- Please post JPGs or PNGs... BMPs are really huge. ;)
post-10515-1223308535.png?width=400
