Xtian Andres Posted October 8, 2008 Report Posted October 8, 2008 Hi!!! i'm really new on LabVIEW. but i have this problem: i have images storaged into a db of Mysql, the images are into a BLOB field, i wanto to make some sort of select and show the image into a picture control, even in any control. I know how to make the conection and retrieve the information from the database, but i dont know how to put it into the picture control, i even tried using the picture control and give to it "Enable Database access" but i dont figure how use it thanks Ok, i found in the NI site a solution do it for access, but im using it . At this moment i made some changes to the example. but still doesnt want to paint the image. it told me that the variant type is not accord with the type that i want. i store that image using java, as a array of bytes..... Quote
LAVA 1.0 Content Posted October 8, 2008 Report Posted October 8, 2008 QUOTE (Xtian Andres @ Oct 7 2008, 01:24 PM) i store that image using java, as a array of bytes..... What is the representation of your array constant? Ton Quote
Xtian Andres Posted October 8, 2008 Author Report Posted October 8, 2008 QUOTE (Ton @ Oct 7 2008, 01:14 PM) What is the representation of your array constant?Ton is unsigned byte, I already tried with signed byte Quote
