HChandler Posted October 11, 2008 Report Posted October 11, 2008 Hey y'all I really dig the openG "fit to largest decoration" function. Is there a quick and easy way to make it into a "fit to named decoration" function? I could put a bunch of related dialogs on the same front panel that way. Thanks Quote
Dave Graybeal Posted October 11, 2008 Report Posted October 11, 2008 Someone correct me if I'm wrong here, but I don't believe decorations have names so it would be sorta tough to fit to named decoration. Unless of course you mean something along the lines of fit to named control / indicator ? Dave Quote
HChandler Posted October 11, 2008 Author Report Posted October 11, 2008 O crap! they don't! They must have some sort of handle. Perhaps it could be done by array index number. Are they numbered in the order they're dropped on the panel? QUOTE (Dave Graybeal @ Oct 10 2008, 12:28 PM) Someone correct me if I'm wrong here, but I don't believe decorations have names so it would be sorta tough to fit to named decoration.Unless of course you mean something along the lines of fit to named control / indicator ? Dave Quote
Francois Normandin Posted October 11, 2008 Report Posted October 11, 2008 QUOTE (HChandler @ Oct 10 2008, 01:52 PM) O crap! they don't!They must have some sort of handle. Perhaps it could be done by array index number. Are they numbered in the order they're dropped on the panel? You can have a list of refnums to all decorations, so yes indexing would work. Quote
crelf Posted October 14, 2008 Report Posted October 14, 2008 QUOTE (HChandler @ Oct 10 2008, 01:52 PM) They must have some sort of handle. Perhaps it could be done by array index number. Are they numbered in the order they're dropped on the panel? Using the flat square button in the old classic palette is a good compromise - you can refer to if by name, and also lock it to your panel so it doesn't move when you select things on top of it: http://lavag.org/old_files/monthly_10_2008/post-181-1223858453.png' target="_blank"> Quote
