Join of two bytes
QUOTE (d_nikolaos @ Oct 13 2008, 07:51 AM)
I want to join 2 bytes that I take them from the serial port. Is that possible?
Except for that, I want to have somethink like start and stop.
I want to sent from a PIC through the RS232 some numbers in dec form like ('#19*')
# = start byte
* = stop byte
Is that possible?
Everything is possible, but what kind of inputs and outputs are you looking for?
Check out "Concatenate String", "Format Into String", the String/Number Conversion palette, and possibly the Data Manipulation palette.
It would also help if you post some code (or a block diagram screen capture) of what you are trying to do.
My input will be 12 bits. But with the RS232 protocol I have to split these 12 bits to 8 and 4 bits.
So finaly my input will be 8bits the first time and 4 bits the second.
Then I want to join them with some way and then I will convert this number to a decemical form.
So my input is somethink like this 00001101 and 0010 and my output 525.
QUOTE (d_nikolaos @ Oct 14 2008, 08:32 AM)
So finaly my input will be 8bits the first time and 4 bits the second...
As jdunham said, it would really help if you could post some code.
To combine two 8 bit numbers into one 16bit number, you can use the "Join Numbers" primitive in LabVIEW.
I don't know if you transfer the data in network byte order, or intel byte order, but you can handle either case with the "Join Numbers"
/J
QUOTE (d_nikolaos @ Oct 14 2008, 10:13 AM)
...how I can make this function to understand that the first 8 bits is hi and the other 8 bits is lo.
Second how I can convert this 16bit to number...
The output is a 16bit number.
To change the order of the Hi and Low bytes, just wire the node in different order.
Use the LabVIEW contextual help to display how a function is used.
/J
