Folder copy... bad behavior?
This may be a bug, or may be just an "expected behavior". Given that it's not hard to reproduce, I suspect it's been seen before.
Reproduce:
1. In the Windows file system, create the folders C:\Original, C:\Original\Path1, and C:\Original\Path2.
2. Run the attached VI.
Expected either:
1. An error: the folder C:\Destination does not exist.
or
2. No error, and the folders C:\Destination\Path1 and C:\Destination\Path2 are created.
Actual result, no errors:
1. First iteration of the loop creates C:\Destination
2. Second iteration of the loop creates C:\Destination\Path2
Can anyone provide confirmation or insight?
Thanks,
Joe Z.
I've attached an image so those without LV8.6 can comment.
Looking at the built-in help docs for the copy function we read this:
QUOTE
For example, if you copy the directory c:\app to d:\app2, the function creates a new directory d:\app2 with the same contents as c:\app. The second time you copy the directory, the function creates a new subdirectory d:\app2\app and places the contents of app there. The third time you copy the directory, the function returns a Duplicate Path error.
Thanks Michael, that's the information I needed. Now I can program around it.
Whether it's "good" behavior or not, I don't know.
Joe Z.
Edit: Script blocker != good formatting
