Counter Timer Frequency Ranges
ASTDan
Hello,
I know this info is somewhere but I am having a hard time trying to find it.
When using a Counter/timer to measure frequency there are multiple methods.
i.e. Low Frequency with 1 counter and high frequency with 2 counters.
What is the definition of a "low frequency" and what is the definition of a "high frequency"? i.e. low frequency = frequencies below 100 Hz
Also what is the definition of a "large range"?
Thanks
Dan
QUOTE (ASTDan @ Nov 2 2008, 11:00 AM)
Hello,
Thanks
Dan
How many bit is the counter and how often will you be reading it? If there is a possibility of rollover, you will need two CTRs otherwise one will suffice. But, this only matters if you need to count every pulse. (No political comments please :P ) If you are just measuring frequency and duty cycle this shouldn't be an issue.
