ASTDan Posted November 3, 2008 Report Share Posted November 3, 2008 Hello, I know this info is somewhere but I am having a hard time trying to find it. When using a Counter/timer to measure frequency there are multiple methods. i.e. Low Frequency with 1 counter and high frequency with 2 counters. What is the definition of a "low frequency" and what is the definition of a "high frequency"? i.e. low frequency = frequencies below 100 Hz Also what is the definition of a "large range"? Thanks Dan Quote Link to comment
gleichman Posted November 3, 2008 Report Share Posted November 3, 2008 QUOTE (ASTDan @ Nov 2 2008, 11:00 AM) Hello,I know this info is somewhere but I am having a hard time trying to find it. When using a Counter/timer to measure frequency there are multiple methods. i.e. Low Frequency with 1 counter and high frequency with 2 counters. What is the definition of a "low frequency" and what is the definition of a "high frequency"? i.e. low frequency = frequencies below 100 Hz Also what is the definition of a "large range"? Thanks Dan How many bit is the counter and how often will you be reading it? If there is a possibility of rollover, you will need two CTRs otherwise one will suffice. But, this only matters if you need to count every pulse. (No political comments please ) If you are just measuring frequency and duty cycle this shouldn't be an issue. Quote Link to comment
