How to extract elapsed time from Elapsed Timer before resetting programmatically
Here's a newbie problem. I'm trying to extract how much time is spent inside an event structure activated by a switch control. I'm using a Elapsed Timer function. I reset the function when leaving the event structure but before leaving reseting I need the elapsed time. It seems that the reset has priority so my elapsed time always gets initialized to 0 before sending my info. Any suggestions?
QUOTE (Atif @ Nov 7 2008, 11:47 PM)
I'm not sure what your trying to measure? Can you post an example? Its likely that the function in question does, in fact, execute faster than 1 millisecond. In which case you'll need to use the VI Profiler toolkit or other means to perform the benchmark.
If you notice I'm trying to grab "TimeElapsedInEvent" and pass it to a local var outside the event struct. But when I reset the Elapsed Time2 as I'm leaving the event struct, it initializes the Elapsed Time output back to 0. I would like to grab the Elapsed Time before it gets initialized.
Please don't be offended... but your code is a mess. (Local/Global variables tend to do that!). To be honest, if I didn't recognize the front panel as being the Car Wash CLD example I would have had no clue what you trying to do. Also, using the event structure this way is ill advised. The event code should be short and sweet. Placing a while loop in there sort of defeats its purpose.
Of course, I realize that your a new user and I'm here to help. I've attached a simplified version of the VI. I used locals (and event structure) only to demonstrate a possible "working" solution... but ultimately this is not a very good approach.
QUOTE (Dan DeFriese @ Nov 9 2008, 08:44 PM)
No offense taken at all. I know its ugly...I would've treated someone the same if it was in C/C++. I have a lot to learn about shift registers. Thanks for your help though
QUOTE (Atif @ Nov 10 2008, 08:41 PM)
Maybe I should show you some of my C/C++ code (or VBA which I just started playing with a few weeks ago :o ).
Have you peaked at the NI example code yet?
