rom9 Posted November 11, 2008 Report Posted November 11, 2008 Hi I am having trouble analysing Power Spectrum and Power Spectrum Density. I am measuring signals from a channel from which I need to get the squaredVrms values which is obtained by intergrating the area under the curve of a Lorentzian Peak from the Power Spectrum. I tried using both Power Spectrum and Power Spectrum density from the Express VIs. However as I increase the number of samples from say 5000 samples to 20000 samples at 50KHz, the area under the resonance peak at roughly 15kHz keeps decreasing leading to a different value everytime I change the sampling rate. Is there an explanation to this ? I kept all the other factors like number of averages etc constant. Would really appreciate the help Thanks Quote
Anders Björk Posted November 11, 2008 Report Posted November 11, 2008 Could you give an example how much less i precent it gets? I think it has to do with the scaling the y-axis of the powerspectra, you could look it up in DSP book. Quote
rom9 Posted November 12, 2008 Author Report Posted November 12, 2008 QUOTE (Anders Björk @ Nov 10 2008, 10:52 PM) Could you give an example how much less i precent it gets? I think it has to do with the scaling the y-axis of the powerspectra, you could look it up in DSP book. Hi Anders Thanks for taking your time. The value changes from 2E-4 at 5000 samples to 8E-5 at 10000 samples, thats an order of magnitude in change. This is what bother me, since if it was only a few percent, i could attribute it to noise or the curve fitting. I used Igor and Origin both to do the curve fitting. I also tried to use power spectral density VI instead of the power spectrum, but got similar results. Quote
