Need to workaround ugly marker
DanielChile
Hello, everyone. I need help from the UI masters.
Please see the attached VI (LV 8.5.1). You may notice an ugly "xxxxxxE-15" on the Y scale of the graph where it should be a simple zero. Note that this scale has scaling factors.
I suppose this is a bug and we wanted to workaround it. We figured out that we could read all markers text and then just write a "0" to the ugly one, but we still can't get the right method.
Any suggestions?
Daniel R.
I just adjusted the formatting of the Y axis of the control.
Right click the graph.
In the context menu select: Y Axis -> Formatting.
I adjusted formatting to be floating point w/4 digits of precision.
Hope this helps,
Dan
QUOTE (DanielChile @ Nov 28 2008, 01:54 AM)
Any suggestions?
Daniel R.
Programatically you can use the YScale>>Format and Precision property nodes to set these settings. File Attached
