vultac Posted December 1, 2008 Report Posted December 1, 2008 Hi guys, ive been wondering if there is anywhere in labview that i could program something so that the 1st 2bits would stay constant after i apply an addition to the previous set of bits after a for loop everyttime? for eg. (starting bit) (first 2 bits doesnt change) (first 2 bit doesnt change) 00000010 -> 00000110 -> 00001110 ??? Quote
Justin Goeres Posted December 1, 2008 Report Posted December 1, 2008 QUOTE (vultac @ Nov 29 2008, 06:43 PM) Hi guys, ive been wondering if there is anywhere in labview that i could program something so that the 1st 2bits would stay constant after i apply an addition to the previous set of bits after a for loop everyttime?for eg. (starting bit) (first 2 bits doesnt change) (first 2 bit doesnt change) 00000010 -> 00000110 -> 00001110 ??? The tools you need are in the Programming >> Boolean and Programming >> Numeric >> Data Manipulation palettes. The boolean logic functions (AND/OR/XOR/etc.) will all operate bitwise if you pass in U32/I32/etc. data, and there are also shift and rotate functions. Quote
B Chavez Posted December 3, 2008 Report Posted December 3, 2008 QUOTE (vultac @ Nov 29 2008, 06:43 PM) Hi guys, ive been wondering if there is anywhere in labview that i could program something so that the 1st 2bits would stay constant after i apply an addition to the previous set of bits after a for loop everyttime?for eg. (starting bit) (first 2 bits doesnt change) (first 2 bit doesnt change) 00000010 -> 00000110 -> 00001110 ??? If you want to leave the lower two bits alone, then simply increment by 4; incrementing by 8 leaves the lower 3 bits alone, by 16 leaves the lower 4 alone, etc. Quote
vultac Posted December 3, 2008 Author Report Posted December 3, 2008 wow. lol!! smart smart thanks!!! Quote
