asbo Posted December 8, 2008 Report Posted December 8, 2008 In a text-based language, you can talk about how many lines your application is. For LabVIEW, I've seen people talk about x number of VIs in a project, but I don't think that's a very accurate representation of a project's complexity - what if you happen to have 50 functional globals? Who wants to write a tool which will count the number of wires you use? :> Quote
crelf Posted December 8, 2008 Report Posted December 8, 2008 QUOTE (asbo @ Dec 7 2008, 04:57 PM) In a text-based language, you can talk about how many lines your application is. For LabVIEW, I've seen people talk about x number of VIs in a project, but I don't think that's a very accurate representation of a project's complexity... Have a look at http://forums.lavag.org/Node-count-versus-SLOC-t3632.html' target="_blank">this. Quote
asbo Posted December 9, 2008 Author Report Posted December 9, 2008 Quite the bag of tricks you have there, Mr. Relf. Quote
crelf Posted December 9, 2008 Report Posted December 9, 2008 QUOTE (asbo @ Dec 8 2008, 10:31 AM) Quite the bag of tricks you have there, Mr. Relf. It's what I do. Quote
orko Posted December 10, 2008 Report Posted December 10, 2008 QUOTE (asbo @ Dec 7 2008, 01:57 PM) In a text-based language, you can talk about how many lines your application is. For LabVIEW, I've seen people talk about x number of VIs in a project, but I don't think that's a very accurate representation of a project's complexity - what if you happen to have 50 functional globals?Who wants to write a tool which will count the number of wires you use? :> You should also take a look at http://zone.ni.com/devzone/cda/tut/p/id/3324' target="_blank">This. Quote
crelf Posted December 10, 2008 Report Posted December 10, 2008 QUOTE (orko @ Dec 9 2008, 03:16 PM) You should also take a look at http://zone.ni.com/devzone/cda/tut/p/id/3324' target="_blank">This. That article says: "National Instruments compared the number of LabVIEW nodes used to the equivalent C SLOC and found there was roughly a one-to-one relationship between LabVIEW nodes and SLOC." That's a big call without any supporting data. I'm not saying that it's not true for a particular code size, but I'd like to see some correlational data before I'd beleive that. PS: that article is titled "Estimating Code Complexity in LabVIEW" - IMHO, complexity and code size are two very different things. I think tying to tie SLOC to complexity is inappropriate. Complexity isn't size - it's, errrrrr, complexity. Quote
orko Posted December 10, 2008 Report Posted December 10, 2008 Yep, apples and oranges... estimators who don't know anything about LabVIEW won't care though. As far as complexity goes, it was once said to me that "complexity is a symptom of confusion, not the cause." I don't know how many times I've seen a huge, complex, beastly design reduced to beautiful, clean, precise simplicity by someone with more experience and wisdom. This is true for any language, and is one of the reasons I don't take much stock in assigning resources/value based on how large a project is estimated to be. Big is not always better. Quote
crelf Posted December 10, 2008 Report Posted December 10, 2008 QUOTE (orko @ Dec 9 2008, 04:58 PM) I don't know how many times I've seen a huge, complex, beastly design reduced to beautiful, clean, precise simplicity by someone with more experience and wisdom. This is true for any language, and is one of the reasons I don't take much stock in assigning resources/value based on how large a project is estimated to be. PS: we have a LabVIEW complexity metric that we use too Quote
