Synaesthesiac Posted December 10, 2008 Report Posted December 10, 2008 Hello all-- I've not even begun to explore the scripting features in LabVIEW, but am wondering if it is possible to write a script that generates a type def consisting of multiple controls (e.g. a type defined cluster of strings, booleans, etc.) and saves it as a .ctl file. What would be really excellent is if I could pass a flattened xml string that defines the controls (in the same format as is outputted from a "flatten to xml" node), and generate a .ctl file from that. If this is possible, I might start to really delve in to LabVIEW scripting Quote
LAVA 1.0 Content Posted December 11, 2008 Report Posted December 11, 2008 The Variant To Control Code Repository solution will convert any variant to a .ctl file. Selectively this control can be a (strict) type def. You can build an arbitrary variant using OpenG data tools Have fun, Ton Quote
