rs232 and USB2.0 question
v_pan
hello everybody..
i made a project based on microcontroller and communicate with 232.
my baud rate is at 115200bps and proved to be very poor for what i want to do.
i'm thinking to change my communication to usb2.0 (microcontroller support )
my question is ..
if i do this ,do i have to change my program on labview?
i mean ..
now i select COM1 to communicate with micro
after change this
the only thing i have to do is to change COM1 to COM4 for example?
and increase baud rate
or i have to do more things on program>?
QUOTE (v_pan @ Dec 14 2008, 03:31 AM)
hello everybody..
my question is ..
i mean ..
after change this
Hello,
If what you changed is just adding a RS232 to USB2.0 converter, like what you have said it shows up as COM4, then nothing on speed will improve, even though it is connected to USB port and use a USB cable, but underlying communication protocal is same, it is still RS232. To fully make use of USB protocal, you need to use a true USB device, not a simulated COM port. Regarding the LabVIEW code, yes, you only need to change COM1 to COM4 if you use a RS232 to USB converter, no other code changes needed.
Irene
i will use a PIC microcontrolle that supports USB2.0 hardware.i will make software of USB protocal .
so, output from PIC will be a usb cable (not rs232 to usb converter) and i 'll plug it to one of my usb2.0 port
on my computer
in that case, will LABVIEW recognise this PORT as serial(COM4 for example) or usb?
can i increase speed that way?
thanks for answer!!
QUOTE (v_pan @ Dec 14 2008, 04:53 AM)
on my computer
thanks for answer!!
Well, it depends on what firmware you implemented in the hardware. If you have COM type firmware, then it is just a RS232 to USB converter. For a true USB2.0 device, you should be able to stream your data very fast.
Irene
  • 2 months later...
