crelf Posted December 25, 2008 Report Posted December 25, 2008 Can you set "Scale all objects on front panel as the window resizes" dynamically? Here's the static method: But I don't see see it in the properties list for dynamic control: Quote
Mark Yedinak Posted December 25, 2008 Report Posted December 25, 2008 I am not sure about the entire front panel but it is possible when using splitter bars and separate window panes. The catch though is that you can only get to the method from the front panel. You highlight the splitter bar, select which pane you want and create an invoke node from there. I ran across this myself recently and this approach was given to be by NI. I am not sure why you can't create the invoke node directly but this does work. Quote
jgcode Posted December 26, 2008 Report Posted December 26, 2008 QUOTE (crelf @ Dec 25 2008, 05:10 AM) Quote Can you set "Scale all objects on front panel as the window resizes" dynamically? Here's the static method:But I don't see see it in the properties list for dynamic control: Hi crelf, its an invoke node of a pane. http://lavag.org/old_files/monthly_12_2008/post-10325-1230169711.png' target="_blank"> Quote
crelf Posted December 27, 2008 Author Report Posted December 27, 2008 QUOTE (jgcode @ Dec 24 2008, 08:49 PM) Quote its an invoke node of a pane. Bugger me - of course it is. Thanks mate! Quote
