msaf Posted January 3, 2009 Report Posted January 3, 2009 Hello, I need to save a list of times, in which the data is read by the data acquisition device, as a .txt or .xls file. Unfortunately, the data produced by the 'Get Date/Time' function is a string and can not be written in an .xls file. I can not append the time data in a .txt file to make a list. I appreciate if you could help me with this. Thanks. Quote
Francois Normandin Posted January 3, 2009 Report Posted January 3, 2009 QUOTE (msaf @ Jan 2 2009, 05:41 PM) Hello,I need to save a list of times, in which the data is read by the data acquisition device, as a .txt or .xls file. Unfortunately, the data produced by the 'Get Date/Time' function is a string and can not be written in an .xls file. I can not append the time data in a .txt file to make a list. I appreciate if you could help me with this. Thanks. You need to get a numeric instead of a string. Use the "Get Time/Date in Seconds" function of simply "Tick Count (ms)". See example below. http://lavag.org/old_files/monthly_01_2009/post-10515-1230939142.png' target="_blank"> Quote
msaf Posted January 4, 2009 Author Report Posted January 4, 2009 QUOTE (normandinf @ Jan 2 2009, 03:03 PM) You need to get a numeric instead of a string. Use the "Get Time/Date in Seconds" function of simply "Tick Count (ms)". See example below. http://lavag.org/old_files/monthly_01_2009/post-10515-1230939142.png' target="_blank"> Thanks a lot Normandinf! Quote
