Maci Posted January 15, 2009 Report Posted January 15, 2009 Greatings, we have started a motion control project in LabView 8.2. We kept going with this version until the project completion this past week. We now have Version 8.6, which we want (woke up!) to use instead of 8.2 for future upgrades of the design. When opening the RT vi, the follwing files could not be loaded. I was told that these are part the NI Drivers. I did install these drivers, and still could not be loaded. I looked them up using Windows explorer, but could not find them. Are these hidden files? Are they stored differently between the 8.2 and 8.6? Please, help. The RT vi attempts to loaded these files from <vilib>:\motion\softmotion\nisoftmotion\ ... by searching in C:\Programe Files\National Instruments\LabView 8.6\instr.lib\niTuner\dependency nimcDMTG_SetTimerPeriodAllAxes.vi nimcDMTG_DeleteInstance.vi nimcDMTG_StopCoordinate.vi nimcDMTG_SatrtCoordinate.vi nimcDMTG_LVSetCoordinatePositions.vi nimcDMTG_GetCoordTrajData.vi nimcDMTG_SetAxesInCoordinateSpace.vi nimcDMTG_CreateInstance.vi nimcDMTG_Execute.vi _nimcDMTG_CoordinateMoveType.vi _nimcDMTG_nimcDMTG_CS_Enum.ctl nimcDMTG_LVWriteCoordinateData.vi _nimcDMMain_CommInterface_Data.ctl Quote
LAVA 1.0 Content Posted January 15, 2009 Report Posted January 15, 2009 Did you install the motion toolkit after LabVIEW 8.6 RealTime? Ton Quote
Maci Posted January 20, 2009 Author Report Posted January 20, 2009 QUOTE (Ton @ Jan 14 2009, 10:06 AM) Did you install the motion toolkit after LabVIEW 8.6 RealTime?Ton Ton, is this kit something that is automatically part of the 8.6 version or is it a separate option that needs to be purchase? Our 8.6 package was a separately purchase all together. Quote
LAVA 1.0 Content Posted January 20, 2009 Report Posted January 20, 2009 Your code uses motion which is a seperate toolkit (allthough I think you can install the 8.2 version on 8.6). You have that toolkit installed on LabVIEW 8.2. Now you need to install the toolkit on LabVIEW 8.6, look through your 8.2 CD and try to find the toolkit. It might happen that installing the toolkit on 8.6 deinstalls the toolkit on 8.6. Ton Quote
Maci Posted January 31, 2009 Author Report Posted January 31, 2009 QUOTE (Ton @ Jan 19 2009, 03:20 AM) Your code uses motion which is a seperate toolkit (allthough I think you can install the 8.2 version on 8.6).You have that toolkit installed on LabVIEW 8.2. Now you need to install the toolkit on LabVIEW 8.6, look through your 8.2 CD and try to find the toolkit. It might happen that installing the toolkit on 8.6 deinstalls the toolkit on 8.6. Ton Thank you for your input, Ton. I figured it out. Thank you, again Quote
shaddie Posted March 21, 2009 Report Posted March 21, 2009 QUOTE (Maci @ Jan 29 2009, 09:06 PM) Thank you for your input, Ton. I figured it out. Thank you, again How did you figure it out? Quote
