Battery life test GUI
Rabbit
I am going to design test toolkit for battery charge and discharge testing. enclosed file is GUI, anybody can give better comments.
the GUI implement with following features.
Graphic battery voltage and discharge/charge current.
list tab shows the measurement and show high/low limits
battery bar show battery level,
attched is GUI for reference.
QUOTE (Rabbit @ Jan 15 2009, 11:47 AM)
If you do a exe, the "stop" button will exit/quit?
May want to add a version number (soft)
Look good
Some questions as a user:
  • I see a Stop button. What are you stopping?
  • Where's the Start button? What are you starting?
  • Is the test information all controls or indicators? If they are indicators then how do you edit the info?
  • What's Crossfire and Gamepad? Why are they important to me?
  • Why does the indicator say Idle? Isn't it more important to know when it's running?
  • Is battery level in Volts?
  • I don't see any units in your Measurement table (or the graphs and legend)
All the above questions should be answerd easily by just looking at the UI. Anyway, I just did a quick pass at it. Also, I like to see the UI interaction flow go from Left to right (ie. Test Information on the left) but perhaps in China it's different.
