NI PXI-4461 Error -223022
malentina
Hello,
I have a intermittent problem with a NI PXI-4461, I saw two cases:
* First when I changed the PXI-controller in the chassis (I used to used two 8105 and 8106), the devices simply doesn't work.
- If I select the option Self-Test in MAX appears the next message.
(The device self test has failes. The error report from the device driver is as follows: Error -223022 occurred at Self Test)
* Second If I let a long period of time (1 or 2 days) without use the device and I try to use it, again doesn't work and MAX report the same message.
I need to reset the controller to can run the project that use the 4461.
I only found this case but is not working...
http://forums.ni.com/ni/board/message?boar...message.id=2340
I haven't found the solution, Can anybody help me, please?
I use:
Labview 82 and 86
VISA 4.0 4.0
Ni-DAQmx 8.3 74
Best Regards
MP
Hello,
I use:
Labview 82 and 86
VISA 4.0 4.0
Ni-DAQmx 8.3 74
Best Regards
MP
