GSR Posted January 25, 2009 Report Posted January 25, 2009 Dear all, I read a few sources of control parallel port because I have a question of controlling signal bit in parallel port. One of them use "out port vi", but what is the register address to go to the VI and how I can find out the address. The other one suggests to use VISA, I used VISA to control serial port. However, I have no clue how to use VISA to control a signal bit in parallel port. Quote
zythum Posted January 25, 2009 Report Posted January 25, 2009 QUOTE (zmarcoz @ Jan 24 2009, 12:09 AM) Dear all,I read a few sources of control parallel port because I have a question of controlling signal bit in parallel port. One of them use "out port vi", but what is the register address to go to the VI and how I can find out the address. Under Windows XP, right click on "My Computer" (or using the hot key WindowsLogo+Break) go to Hardware, Device Manager and expend Port (COM & LPT). Then, 2 click on your LPT, go to resources and you will get the 4 address. Take the first. Be careful, this is 0x378, not 378. (0x378 is a standard on most computer)QUOTE (zmarcoz @ Jan 24 2009, 12:09 AM) <LI>The other one suggests to use VISA, I used VISA to control serial port. However, I have no clue how to use VISA to control a signal bit in parallel port. Me too, in more, I use LabView 6.1 (last week). I use "out port vi" and the docs that I found on NI web site. Sorry, I can't get you the address, ni.com is down for update. Hope this help you *** I think this was post on wrong forum....**** Zythum Quote
malef Posted January 27, 2009 Report Posted January 27, 2009 A snippet how to make use of LPT via OutPort.vi Quote
