Writing data to standard out
Mark Yedinak
How can I write data back out to standard out from a built application? I have a stand-alone executable that takes command line arguments and I want to be able to write an error message back out to standard out if the command line arguments are invalid. How can this be done?
QUOTE (Phillip Brooks @ Feb 5 2009, 12:49 PM)
This is a GUI application which needs to be able to be run from the command line. Essentially this is a tool that can be used by a person sitting down and interacting with it or it can be invoked automatically and run in a non-interactive mode. Since we need command lines arguments to support this functionality I would line to be able to print an error message back out to the command prompt if the command line arguments are incorrect. I suppose I could display a dialog box with the error message but it seems to be much more straightforward to simply print the message out to the command line.
