LAVA 1.0 Content Posted February 10, 2009 Report Posted February 10, 2009 If you edit a page with multiple templates in a row (like the Configuration pages) with the new editor. The layout will be scrambled. The templates will be prepended next to each other with a space in between. The space should be replaced by a new-line. A workaround: after editing with the new editor, switch to wiki view copy the contents to a text editor and do a search and replace on }}/s{{ and replace that with }}/n/n{{ with notepad++ for instance. Using the double /n delimiter will make sure the enter stays in place. Ton Quote
Michael Aivaliotis Posted February 10, 2009 Report Posted February 10, 2009 An easier fix is just to make sure there is a blank line between each instance of the template. Quote
