Getting started with RIO/FPGA
CraigGraham
We have to put a bid in on a project that the client has decided to use Compact RIO for. New toys they want to play with. I've not done it before so I've been playing with the FPGA module and FPGA interface in Labview 8.
Actually doing FPGA code and running it on a bit of hardware set as emulated works fine, but I need to be able to communicate with a UI VI on the host PC. When I (or any of the examples) try to open a reference to the FPGA VI from the host, an error is generated to the effect that Labview can't find the hardware. Should I be able to do this on emulated hardware or is the emulation only there for playing with the FPGA code in isolation?
Before it's suggested, we're not buying the hardware to play with in order to make an informed bid. :)
