reshaping bmp distorted
Hi, there,
I tried to read a bitmap image, then convert it to a 2D array using 'array reshape', but the resulted image was distorted.
To show that, I convert the 2D array back to picture.
Any ideas?
QUOTE (nicolasB @ Feb 14 2009, 09:18 AM)
  Quote
LabView uses the padded width wich is 276 in your example.
Why don't you use the "unflatten pixmap.vi" to obtain a 2D array?
regards,
Nicolas
Nicolas-
Thanks. That works.
Can you elaborate on "padded width"? What kind of machenism is that?
QUOTE (thinhare @ Feb 14 2009, 11:10 AM)
  Quote
Nicolas-
Thanks. That works.
this has smoething to do with a 4 Byte alignment, but I'm not confident with the details.
