Inconsistent naming for auto-generated class member vis
When creating class member vis using using Right Click -> New..., the naming convention of the class input and output in the automatically generated member vi is not consistent.
New -> VI from Dynamic Dispatch Template and New -> VI from Static Dispatch Template use the class' localized name as set in the class properties dialog box but automatically removes the .lvclass extention.
New -> VI for Data Member Access appears to use the class' filename.
