jgcode Posted February 20, 2009 Report Share Posted February 20, 2009 [cross posted to ni.com] Problem: LabVIEW seems to be overriding a value of 1 to a value of 2 for the Sample Quantity.Sample Per Channel DAQmx Property Node for a Continuous acquisition mode. Information: I have a task set up in MAX (version 4.4.0f1). When I set Samples To Read to 1 the task runs correctly in MAX. When I read the task in LabVIEW (8.5) the Sample Quantity.Sample Per Channel property node (which is the Samples to Read) is coerced to a value of 2. If the value is greater or equal to 2 in MAX then the Sample Quantity.Sample Per Channel property node in LabVIEW returns the correct value. I get the same problem with a real device or a simulated device. Question: Is this desired behavior? Side note: If N Samples (finite buffer acquisition) is selected Samples To Read cannot be 1 as it causes an error 200077 - it must greater or equal to 2. But no error occurs when the task is saved as Continuous (continuous buffer acquisition). I don't know if this is related. The error generated is: Error -200077 occurred at DAQ Assistant Possible Reason(s): Measurements: Requested value is not a supported value for this property. Property: SampQuant.SampPerChan You Have Requested: 1 Valid Values Begin with: 2 Valid Values End with: 8589934590 Device: cDAQ3 Not Expected Expected Quote Link to comment
jgcode Posted February 25, 2009 Author Report Share Posted February 25, 2009 answer in cross post to ni.com Quote Link to comment
