Bjarne Joergensen Posted March 7, 2009 Report Posted March 7, 2009 Hi This is strange (for me ). Try open these 2 VIs and run the "TestVIStart.VI". Then TestSub.VI start. Download File:post-7489-1236342950.viDownload File:post-7489-1236342962.vi When the Boolean stop blinking, then you shall top the TestVIStart.vi by the Stop button. Now watch the size of the FP on TestSub.vi. Start the first VI again and see the FP size is growing bigger on the TestSub.vi, when you stop the TestVIStart.vi. :headbang: Watch also that the FP has change it's position in run mode. :ninja: I have set the VI properties this way on the TestSub.vi: If I change the window appearance to Default, then it won't happen. Is there a good explanation for that behaviour? Use LV8.2.1 Regards Bjarne Quote
