help!
Hi everybody
Ihave a file that does the Knight Rider Flasher but I need a help in the following points.
Use the Knight Rider Flasher program and modify it for the following
functionality:
1. Modify the logic so that the same sequence is displayed without using the
‘Indexed Array’ and ‘Remainder Quotient’ block as used in the class.
2. Modify the control logic so that you start the program only once using the
SINGLE RUN button and it should start working in the continuous mode.
3. Whenever a STOP button (same one that was used for stopping the WHILE
loop) is pressed, the flasher must freeze wherever it was without terminating
the program.
4. If this STOP button is pressed again then the Flasher must start from the
same point where it got frozen in the previous step. It should NOT start from
the beginning!
I've posted the file I've made but if anybody can help me in this I will really appreciate it..
Thanks again
QUOTE (Dan DeFriese @ Mar 6 2009, 06:17 PM)
Sounds like your assignment is to devise an alternate approach for the implementation. Naturally, if one of use does it for you won't learn anything. But I'll give you a hint: study the behaviour of unitialized shift registers.
Regards
~Dan
Thanx alot and I don't want the solution but I just need any help or hint. I will Try to learn what you suggested.
Thanks again
Regards
~Dan
hi again
Mr.Dan what do you mean by this word 'unitialized '???
