Using .NET and getting Error 1172
post-7622-1237317801.jpg?width=400
Hello Techies
I wanted to make a reference to a .NET .dll for use in Labview.
I started out by creating a .NET Refnum control and then connecting that to a Property Node. I could see all the properties, but when I ran the VI, I got Error 1172
(see the attachment)
My 2nd idea was to use a Constructor (for the object I wanted), then connect that to the Property Node. Now this seems to work with no error.
My question is:
1) Is there a better way of referencing the dll in my VI other than using a Constructor (...then getting the properties?) or am I doing this correctly with the 2nd idea?
thanks
The Rookie
QUOTE (jaehov @ Mar 17 2009, 12:24 PM)
http://lavag.org/old_files/monthly_03_2009/post-7622-1237317801.jpg' target="_blank">post-7622-1237317801.jpg?width=400
Hello Techies
My question is:
thanks
The Rookie
Nope, that's what you have to do. Unless you're trying to access static methods or properties, you have to instantiate the object with the constructor node before any object exists that has any methods or properties.
Mark
QUOTE (mesmith @ Mar 17 2009, 03:42 PM)
Mark
ok sounds good. But just out of curiosity, what did you mean by access "static" methods or properties? What Labview controls would I use then?
thanks
J
QUOTE (jaehov @ Mar 17 2009, 12:56 PM)
See this article to start
http://en.wikipedia.org/wiki/Method_(compu...#Static_methods
This also applies to static properties
In LabVIEW, when you browse the pulldown list of methods or properties from the .NET Property or Invoke node, the static members are preceded by . You can use the static methods or properties without first instantiating an object.
Mark
