laiwei Posted March 20, 2009 Report Share Posted March 20, 2009 I'd like to draw points and lines using point coordination. I don't want use Create Mesh.vi, because line style can not be changed. Any suggestion? Thanks. Quote Link to comment
Justin Reina Posted March 20, 2009 Report Share Posted March 20, 2009 Hello Laiwei, Don't call this the end of the battle, but I couldn't find any modifiable properties for the 3D Picture Control for lines. It appears the only way to add primitives is through ->'Set Drawable', and this only includes items already found on the palette. If someone does find it though, let me know I do know this; last summer I spent significant time trying to find specific options within the 3D Picture Control, to no avail. I might suggest trying to find a simple alternative (I used long cylinders and spheres). And given modern computing, you may never know the difference . But this is also why default Office 2007 graphics look like anime cartoons... Best of luck, Justin *Could your app use a 3D Graph Control? These explicity Support your desires ('3D Curve Graph;) Quote Link to comment
vugie Posted March 20, 2009 Report Share Posted March 20, 2009 QUOTE (laiwei @ Mar 19 2009, 05:00 AM) I'd like to draw points and lines using point coordination. I don't want use Create Mesh.vi, because line style can not be changed. Any suggestion? Thanks. What type of styles do you want to achieve? You may simply change color and thickness and also gradients if you use "per vertex" color scheme. If you want dashed lines with some extra processing you might be able to cut your input data to dashes. http://forums.lavag.org/post-a11463-3dlines.swf Quote Link to comment
Justin Reina Posted March 21, 2009 Report Share Posted March 21, 2009 vugie, That is excellent, thanks for the submission. Never knew that was there -Justin Quote Link to comment
RobDus Posted May 16, 2009 Report Share Posted May 16, 2009 This example uses dra point to make a mandelbrot picture in labview 8.6.1 enjoi Quote Link to comment
