Can't access Block Diagram property
Okay, so I enabled scripting using the
SuperPrivateScriptingFeatureVisible=True
line in my INI file, and additional properties were added, but the Block Diagram one wasn't! How do I get it there! I'm using LabVIEW 8.5.
QUOTE (Aristos Queue @ Mar 21 2009, 01:01 AM)
  Quote
The token no longer works after LV 7.1.
Does that mean I can't use VI Scripting after 7.1?
QUOTE (flarn2006 @ Mar 21 2009, 11:00 AM)
  Quote
Not in the way you used to be able to do... If you hunt around on LAVA and elsewhere, I'm sure you'll find the latest workarounds.
