SaNoSuke Posted March 25, 2009 Report Share Posted March 25, 2009 Hi, I'm a new user in LabView and doing a project, i would like to know how can i read from two dimensional array in excel sheet (or table) into labview? means i can specify the column and the row from t he labview then read the value from excel ( or sometimes more than one value a time) Regards, M.B Quote Link to comment
PaulL Posted March 25, 2009 Report Share Posted March 25, 2009 QUOTE (SaNoSuke @ Mar 24 2009, 09:43 AM) Hi,I'm a new user in LabView and doing a project, i would like to know how can i read from two dimensional array in excel sheet (or table) into labview? means i can specify the column and the row from t he labview then read the value from excel ( or sometimes more than one value a time) Regards, M.B The "Read From Spreadsheet File.vi" on the File I/O palette should get you there. Quote Link to comment
Mark Smith Posted March 25, 2009 Report Share Posted March 25, 2009 QUOTE (Paul_at_Lowell @ Mar 24 2009, 11:03 AM) The "Read From Spreadsheet File.vi" on the File I/O palette should get you there. I don't think you can use Read from Spreadsheet File on an Excel file - you'll have to save the Excel file as a csv or some other text format first. If you want to read directly from an XLS file, you'll have to use the activeX interface. http://zone.ni.com/devzone/cda/epd/p/id/3409 Mark Edit: added link Quote Link to comment
jhoskins Posted March 26, 2009 Report Share Posted March 26, 2009 QUOTE (mesmith @ Mar 24 2009, 12:26 PM) I don't think you can use Read from Spreadsheet File on an Excel file - you'll have to save the Excel file as a csv or some other text format first. If you want to read directly from an XLS file, you'll have to use the activeX interface.http://zone.ni.com/devzone/cda/epd/p/id/3409 Mark Edit: added link Also for more information about using labview with Excel you can have a look at the example called Write table to Excel. you can find the example by using the example finder. You can also have at look at the Excel thread. :thumbup: Quote Link to comment
SaNoSuke Posted March 27, 2009 Author Report Share Posted March 27, 2009 Hi, thanks a lot guys (Paul at Lowell, mesmith and jhoskins) for your reply's, am working on the solutions given by you, but i have a new issue now, how could i send two counter outputs (two pulses) in the same time if am using the DAQ card(i forgot the number of the card but it comes with one Digital I/O) ? Cause am trying to control stepper motor through driving circuit that it needs two inputs : first for the number of steps , second for the direction, and if i kept the direction input floating the stepper will move forward and backward ........... Quote Link to comment
