Waterppk Posted March 26, 2009 Report Share Posted March 26, 2009 Hello, Running LabView 8.6 I'm using a PXI system and trying to create a build that will run on the PC and also deploy my project on the PXI system. I can create a build file for the PXI and have that run, however if I try to run the PC VI that monitors the network shared variables from the PXI system, it will just try to run over the PXI deployment resulting in the PXI VI's stopping and the PC VI starting. Seems like I'm missing something. . . Bonus points if you can tell me why I can't get the webserver up and running. I have the PXI system set up at 192.168.1.200, my PC is also behind the same router at 192.168.1.100, I have enabled the web server on the PXI system and have all of the "filters" set to asteriks, so I shouldn't be blocking myself from accessing the web server. There are the default files (like Index.htm) in the PXI web root (at C:\ni-rt\system\www) and I can ping the PXI system, however when I navigate to 192.168.1.200 in a browser I get nothing, also going directly to 192.168.1.200/Index.htm returns nothing. Thanks much and let me know if you need more information! Chris Quote Link to comment
Neville D Posted March 26, 2009 Report Share Posted March 26, 2009 Are you able to connect to the remote panel? (Operate>Connect to Remote Panel). What webserver port are you using? Default is 80 which for us is a proxy port so I usually change it to 90. I forget if VI Server has anything to do with it, but just try enabling VI Server on the Remote Target as well. Check the ni-rt.ini file at C:\ on the target to make sure all your settings are correct. N. Quote Link to comment
Waterppk Posted March 26, 2009 Author Report Share Posted March 26, 2009 QUOTE (Waterppk @ Mar 25 2009, 06:06 PM) Hello,Running LabView 8.6 I'm using a PXI system and trying to create a build that will run on the PC and also deploy my project on the PXI system. I can create a build file for the PXI and have that run, however if I try to run the PC VI that monitors the network shared variables from the PXI system, it will just try to run over the PXI deployment resulting in the PXI VI's stopping and the PC VI starting. Seems like I'm missing something. . . Bonus points if you can tell me why I can't get the webserver up and running. I have the PXI system set up at 192.168.1.200, my PC is also behind the same router at 192.168.1.100, I have enabled the web server on the PXI system and have all of the "filters" set to asteriks, so I shouldn't be blocking myself from accessing the web server. There are the default files (like Index.htm) in the PXI web root (at C:\ni-rt\system\www) and I can ping the PXI system, however when I navigate to 192.168.1.200 in a browser I get nothing, also going directly to 192.168.1.200/Index.htm returns nothing. Thanks much and let me know if you need more information! Chris Looks like I can't ping port 80, which would make it hard to handle an http request, any ideas? Chris Quote Link to comment
Neville D Posted March 26, 2009 Report Share Posted March 26, 2009 Read my post above.. chg to port to 90 N. Quote Link to comment
Waterppk Posted March 26, 2009 Author Report Share Posted March 26, 2009 QUOTE (Neville D @ Mar 25 2009, 07:01 PM) Read my post above.. chg to port to 90N. Thanks for the quick response, I hadn't seen it when I posted previously I changed the HTTP port to 90 and tried to connect through a browser (192.168.1.200:90) and get nothing, I also tried pinging ports 80 and 90 and again get nothing. I tried connecting to the Remote Panel and get: Remote panel connection refused by specified server: Make sure LabVIEW Web Server is enabled on specified server I verified my settings in properties (by right clicking on my chassis), however when I FTP'd to it and checked the settings they were not as set, it had: WebServer.Enabled= FALSE I manually edited that line to read: WebServer.Enabled=True and recopied it over but it made no difference. My current ni-rt.ini in the root of the PXI is: [LVRT] CDIntervalTicks= 55 EnableCPULoadDisplay= True LABVIEWRTDir= C:\ni-rt\system PATH= C:\ni-rt\system\; RTCPULoadMonitoringEnabled=True RTEnetRcvMode= 2 RTTarget.ApplicationPath= c:\ni-rt\startup\startup.rtexe RTTarget.EnableFileSharing= True RTTarget.TimeZone= CST6CDT RTTarget.VIPath= C:\ni-rt\startup server.tcp.access= "+*" server.tcp.enabled=True server.tcp.serviceName="Main Application Instance/VI Server" SocketRecvBufferSize= 65535 SocketSendBufferSize= 65535 StartupDLLs=c:\ni-rt\system\taggerrt.dll;c:\ni-rt\system\mxsemb.dll;c:\ni-rt\system\NcRpcSrv.dll;c:\ni-rt\system\nidevldp.dll; c:\ni-rt\system\taggerrt.dll;NiRioRpc.dll;NiViSrvr.dll;c:\ni-rt\system\nipxism.dll;niorbp.dll; WebServer.Enabled=True WebServer.TcpAccess="+*" webservices.SecurityAPIKey="PqVr/ifkAQh+lVrdPIykXlFvg12GhhQFR8H9cUhphgg=:pTe9HRlQuMfJxAG6QCGq7UvoUpJzAzWGKy5SbZ+roSU=" webservices.ValidTimestampWindow=15 [NVE] MessageQueueUpperBound=1000000 [sTARTUP] EarlyStartupLibraries= C:\ni-rt\system\lvuste.dll;C:\ni-rt\system\tsengine.dll;C:\ni-rt\system\nisl_emb.dll; MainExe= /ni-rt/system/emblview.exe [sYSTEMSETTINGS] Comment=00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 Comment_Format=512 Host_Name=EcoCAR-Chassis1 Protect_Reboot=FALSE [TCP_STACK_CONFIG] DNS_Address=0.0.0.0 Gateway=192.168.1.1 IP_Address=192.168.1.200 Subnet_Mask=255.255.255.0 Thanks again for your help! Quote Link to comment
Neville D Posted March 26, 2009 Report Share Posted March 26, 2009 If you are using LV 8.6, check to see you have webserver.conf in the root, and it shows the correct port "Liston 90". Every time you change a setting on the RT in your project it is not immediately apparent whether that setting was actually changed on the target. I think when you "deploy" your code it deploys the settings, but I just always manually check. Your file should look like this: # Web server configuration file.# Generated by LabVIEW 8.6# 10/30/2008 2:30:35 PM## Global Directives#ServerRoot "."LogLevel 2TypesConfig $SERVER_ROOT/mime.typesThreadLimit 10LoadModulePath "./modules" "./LVModules" "./.."LoadModule LVAuth lvauthmoduleLoadModule LVRFP lvrfpmoduleLoadModule dir libdirModuleLoadModule copy libcopyModuleLoadModule esp libespModuleListen 90## Directives that apply to the default server#ServerName LabVIEWDocumentRoot "/ni-rt/system/www"Timeout 60AddHandler LVAuthHandlerAddHandler LVRFPHandlerAddHandler dirHandlerAddHandler espHandler .espAddHandler copyHandlerDirectoryIndex index.htmKeepAlive onKeepAliveTimeout 60 PS moving the Webserver Port value to the separate webserver.conf file has been a recent change in LV 8.6. Previously you just added WebServerPort=90 into your ni-rt.ini and everything worked out OK. N. Quote Link to comment
Waterppk Posted March 26, 2009 Author Report Share Posted March 26, 2009 I do have the niwebserver.conf in the root, I suspected having to deploy to get the settings to change so I was doing that, but it's nice to know where the files are ending up so I can check, here's my niwebserver.conf: # Web server configuration file. # Generated by LabVIEW 8.6 # 3/25/2009 1:05:01 PM # # Global Directives # ServerRoot "." LogLevel 2 TypesConfig $SERVER_ROOT/mime.types ThreadLimit 10 LoadModulePath "./modules" "./LVModules" "./.." LoadModule LVAuth lvauthmodule LoadModule LVRFP lvrfpmodule LoadModule dir libdirModule LoadModule copy libcopyModule LoadModule esp libespModule LoadModule LvExec ws_runtime Listen 90 # # Directives that apply to the default server # ServerName UW HIL DocumentRoot "/ni-rt/system/www" Timeout 60 AddHandler LVAuthHandler AddHandler LVRFPHandler AddHandler dirHandler AddHandler espHandler .esp AddHandler LvExec AddHandler copyHandler DirectoryIndex index.htm KeepAlive on KeepAliveTimeout 60 Good news, I figured out the problem - the NI webserver wasn't an installed component! I went into MAX and checked the installed software and I was wanting to install that component. Bad news - the only reason I was in MAX was because I nuked the ni-rt.ini and redeployed without rebooting. This created a new ni-rt.ini file and so then I rebooted the PXI system (having a 'fresh' ni-rt.ini file), now when it boots it says: "System state: No software installed", so I would imagine in their infinite wisdom some NI programmer felt that LabView should write all the configuration data to the ni-rt.ini, so my system isn't aware that it's configured and ready to go. The good news is that it's still recognized in MAX, but I can't FTP to it to fix the ni-rt.ini Any ideas on how to proceed from here? Format the disk and start over or? Thanks Quote Link to comment
Neville D Posted March 26, 2009 Report Share Posted March 26, 2009 Yes, just reformat, reload all SW components, apply an IP address and go from there. Its pretty quick. Make sure webserver.conf is correct. N. Quote Link to comment
Waterppk Posted March 26, 2009 Author Report Share Posted March 26, 2009 Got it back, just set everything in MAX to reinstall and it rewrote the configuration file (I would imagine). The webserver now works properly, I switched the port back to 80 so the browser wouldn't have any issues and it still works fine. Still don't know how to get a 'full' deploy where I can run a VI on my PC and also have VI's on the RT system running concurrently without issues, the ONLY reason I'm wanting to do this is so the VI's properly deploy everything, like my HTML pages (which I can set to be copied over to the www folder with a deployment, but if I just run the VI on the RT it doesn't copy over). Quote Link to comment
Neville D Posted March 26, 2009 Report Share Posted March 26, 2009 I'm not sure what you mean by "full deploy".. You have to build an executable of your RT code and then download it to the target and set it to run on startup. Reboot the RT and it should run your code. Then you run whatever you want on the host side to get at the published data. I'm no expert with shared variables, preferring to use lower-level TCP communication which is much more flexible but needs more code development. N. Quote Link to comment
ned Posted March 26, 2009 Report Share Posted March 26, 2009 QUOTE (Waterppk @ Mar 25 2009, 02:44 PM) Got it back, just set everything in MAX to reinstall and it rewrote the configuration file (I would imagine). The webserver now works properly, I switched the port back to 80 so the browser wouldn't have any issues and it still works fine. Still don't know how to get a 'full' deploy where I can run a VI on my PC and also have VI's on the RT system running concurrently without issues, the ONLY reason I'm wanting to do this is so the VI's properly deploy everything, like my HTML pages (which I can set to be copied over to the www folder with a deployment, but if I just run the VI on the RT it doesn't copy over). You shouldn't have problems running VIs simultaneously on your RT system and your PC. Do you have all your VIs set up properly as separate targets in your project? All the VIs that run on your PC should be under "My Computer". What happens when you run the RT VIs, then start the PC VIs? If it attemps to download and deploy to the RT system, you're running your PC VIs on the wrong target. You might also try starting the RT VIs, then right-click on the RT target in the project explorer and choose "Disconnect." Your VIs will continue running on the RT system but LabVIEW will disconnect from it. Quote Link to comment
Waterppk Posted March 28, 2009 Author Report Share Posted March 28, 2009 I spoke with someone from LabView who does the actual RT programming (on the LabView side) at a conference today in Milwaukee. He said that my PC vi (it's running on the correct target) would attempt to redeploy the variables if it didn't think they were deployed, he said the same thing you did, that the easiest thing is to create a build for the RT and run that, then to disconnect from the target and run the local files, otherwise of course I could try tracking down the dependencies and figure out what the actual problem is. Thank you both for all of your help! Quote Link to comment
