ssteven121 Posted April 2, 2009 Report Share Posted April 2, 2009 Hi, I believe I might be having a problem with the NI-DAQmx software, so I want to reinstall it. I tried to just install a backup copy of NI-DAQmx 8.1 (the same version I was using previously), but I received an error: "Error 1304. Error writing to file: C:\Program Files\National Instruments\Shared\niorb\nicdxa.ocm. Verify that you have access to that directory". I changed the directory by unchecking read-only, but it still can't write to it. Also, I've seen this program msiblast.exe, and I tried using it, but I'm not sure how to proceed. I see 13 programs that have NI-DAQ in the name (one of them is NI-DAQmx 8.1). Which ones do I choose to uninstall? Thanks for any help, Steven Quote Link to comment
Neville D Posted April 3, 2009 Report Share Posted April 3, 2009 Have you tried "repairing" the install? Add/Remove Programs>National Instruments>NI-DAQmx>repair You will need the install disks though. If that fails, use msiblast to remove all entries that have "DAQ" in them. Then re-install NI-DAQmx. By the way, have you logged on as admin on your PC? maybe you don't have access rights to install/uninstall. N. Quote Link to comment
ssteven121 Posted April 3, 2009 Author Report Share Posted April 3, 2009 QUOTE (Neville D @ Apr 1 2009, 04:04 PM) Have you tried "repairing" the install?Add/Remove Programs>National Instruments>NI-DAQmx>repair You will need the install disks though. If that fails, use msiblast to remove all entries that have "DAQ" in them. Then re-install NI-DAQmx. By the way, have you logged on as admin on your PC? maybe you don't have access rights to install/uninstall. N. I don't have any install disks for NI-DAQmx 8.1; I downloaded it off the NI website. Can I still repair? Also, I am logged in as admin. Thanks for the help, Steven Quote Link to comment
mross Posted April 3, 2009 Report Share Posted April 3, 2009 QUOTE (ssteven121 @ Apr 1 2009, 07:18 PM) I don't have any install disks for NI-DAQmx 8.1; I downloaded it off the NI website. Can I still repair?Also, I am logged in as admin. Thanks for the help, Steven I imagine that ni phone support will help you sort this out. If you have access to them a phone call will be the quickest way to resolve the issue. Quote Link to comment
Neville D Posted April 3, 2009 Report Share Posted April 3, 2009 QUOTE (ssteven121 @ Apr 1 2009, 04:18 PM) I don't have any install disks for NI-DAQmx 8.1; I downloaded it off the NI website. Can I still repair?Also, I am logged in as admin. Thanks for the help, Steven Yes, when it asks for the disks, point it to your downloaded files. Be sure to reboot when required. N. Quote Link to comment
