X_DOT Posted April 3, 2009 Report Share Posted April 3, 2009 Hi everyone. Iam making a RC-car that have to run by its own. to measure distance I was planning on using ultra sonic sensors. I just wanted to test the sensor with a quick labview program but I have hit a wall. Is it possible to send and receive a DIO on the same line on the usb-6009 DAQ? The test should be run sow I sends out only 1 high node and then waits for the high node to return sow I can calculate the distance as a results of the time delay. Sow does anybody know if it is possible to send and receive on the same channel? best Regards Jens Link to comment
PaulG. Posted April 4, 2009 Report Share Posted April 4, 2009 QUOTE (X_DOT @ Apr 2 2009, 03:24 AM) Hi everyone.Iam making a RC-car that have to run by its own. to measure distance I was planning on using ultra sonic sensors. I just wanted to test the sensor with a quick labview program but I have hit a wall. Is it possible to send and receive a DIO on the same line on the usb-6009 DAQ? The test should be run sow I sends out only 1 high node and then waits for the high node to return sow I can calculate the distance as a results of the time delay. Sow does anybody know if it is possible to send and receive on the same channel? best Regards Jens Yes. I've done it with a 6008. Play around with this VI. http://lavag.org/old_files/post-3786-1238762073.vi'>Download File:post-3786-1238762073.vi Link to comment
X_DOT Posted April 5, 2009 Author Report Share Posted April 5, 2009 I can't open the VI Iam using labvieew 8.5.1 sow cannot open a file newer than my version Link to comment
Please sign in to comment
Sign In Now
