voltage sensor vi Problems
Durden
i am working on a voltage sensor project,i just touched labview for like few weeks,
and i'm trying to make a vi that i can turn on the sensor, and once the sensor recieves the voltage from the machine,
the vi will start saving datas, and i get to choose the location of the saved datas.
The problem i'm having right now is that i don't know how to connect my DAQpad 6070E to the VI, i set it up in the MAX, but
everytime i choose the physical channel, i can only choose PXI2Slot2/a0,a1,a2... i don't see my DAQpad 6070E.
And how do i make the vi save data and i get to choose the location?
and there's my vi below, really appreciate if somebody can look it up.
thank you.
QUOTE (JustinReina @ Apr 3 2009, 03:22 PM)
Hello Durden,
Do any error codes get thrown from your DAQmx calls, and if so where do they originate and what do they say?
-Justin
Hi Justin,
I figured that i was using simulated device instead of the real device for my physical channel...
but still, I could find my device in MAX under "Traditional NI-DAQ(Legacy) Device" and the test panel works fine, but not under NI-DAQ Devices.
Therefore, i couldn't choose my device in physical channel, is there anyway i could find it or add it?
Thank you.
-Durden
Hi Justin,
Thanks for all of your responses. You were right about the DAQmx not supporting my DAQPad 6070E, which explains why i couldn't find it on the physical channel.
I really appreciate you taking the time to answer my questions. You've been a lot of help to me :thumbup:
-Lin
