Hide general STOP button
Hello,
I need to hide the general STOP button which is present on the LabVIEW toolbar at runtime (beside the RUN icon)
when running a VI inside LabVIEW.
I know there is a way to hide all this toolbar because I've ever found a vi that had such a feature.
Unfortunately, I haven't the fineast idea how to achieve this.
I really need it because I want that my vi's user press a STOP button on my vi... but not press the general STOP button because
pressing my VI STOP button also close connection to my data acquisition card. If a user uses the general STOP button
the connection with the hardware is not correctly closed and it fails when I want to run my VI again.
There is probably a way to do it using exe deployment with LV runtime but I don't want such a solution because
I want to deploy LV source code... not binary !
Kind regards
Sorry for noise...
I think the solution is here
http://zone.ni.com/reference/en-XX/help/37..._appearance_db/
Select File»VI Properties, select Window Appearance from the Category pull-down menu, and click the Customize button to display this dialog box. By default, the settings take effect when the VI runs.
