postformac Posted April 12, 2009 Report Share Posted April 12, 2009 Hi, I'm reading a floating point number from an external source over serial (its a PIC giving a voltage reading as an ASCII string output) It works great but I am having difficulty finding a way to display the data to a set number of decimal places. I have tried changing my indicator to a number of different display formats, but they all have issues with certain values. For example, if my incoming string reads "1.123" and I set my display format to floating point with 3 digits of precision, don't hide trailing zeros, it works perfectly and shows "1.123" on my indicator. If the incoming string reads "1.023" it then displays "1.0230" on my indicator, I assume that it doesn't count the first zero as a digit. If I hide trailing zeros then it works with either of the above examples but if the string reads "1.100" then I just get "1.1" on my indicator. Either way the number of digits on my indicator changes according to the data coming in. I just want it to show 3 decimal places, so either "1.123", "1.023" or "1.100" depending on the input string. Is there any way to fix it like this? I don't want the display to keep changing the number of digits after the decimal point. Thanks Quote Link to comment
PA-Paul Posted April 12, 2009 Report Share Posted April 12, 2009 Hiya, Just had a play with this in lv 8.6.1, the following setting for the display format (right click on the indicator, then select "Display format") should do what you want: This does assume you're using a "numeric" indicator to display your data... Hope that helps Paul Quote Link to comment
postformac Posted April 12, 2009 Author Report Share Posted April 12, 2009 Thanks for the reply. I had tried it set like that, and was getting the data back as I described in the original post. However, I just tried with a new VI as a test and it works fine. I went back to the original VI and checked all the settings, which were the same, but that was still adding zeros on the end when there was a leading zero (ie. "1.023" would read "1.0230") I went into the advanced editing mode and found that on the new VI it had "%.3f" as the format string but on the original it had "%_3f". I changed it manually and it works perfectly now, not sure what caused that! Thanks anyway Quote Link to comment
Neville D Posted April 14, 2009 Report Share Posted April 14, 2009 QUOTE (postformac @ Apr 11 2009, 09:50 AM) I went back to the original VI and checked all the settings, which were the same, but that was still adding zeros on the end when there was a leading zero (ie. "1.023" would read "1.0230") Check "Hide Trailing zeros" in the menu shown above in another post. Neville. Quote Link to comment
